spun a bearing on the turbo?????
Old Nov 23, 2009 | 10:38 PM
silverbullet1's Avatar
Default spun a bearing on the turbo?????
trying to figure out if i spun a bearing on the turbo? not for sure if its that or possible leak or what? under normal driving the boost guage spools normally, but when i get on it alittle the boost will just to about 42 psi. and drop to like 34-36 and then slowly climb back to about 40. and when it spools up past about 20-25 psi it feels like the truck is loosing power, and also the turbo sounds alot different that it used to sound like. but when i take it easy and drive normal it seems to run just fine and no power lose? any suggestions, and also if anyone can help me with a link to a website for a rebuild kit for the factory turbo.
Old Nov 24, 2009 | 07:43 AM
DieselDanBoy's Avatar
Now im not a turbo expert but here's what i know. you cant spin a bearing in a turbo im pretty sure, most likely a seal around the bearing has blown so the fan has some play in it. what you probably should do it take the intake off the intake side of the turbo and try to wiggle the fan in the turbo, usually if its got play that means its time for a new or rebuilt one.
Old Nov 24, 2009 | 06:43 PM
BigRedFireTruck's Avatar
everything that diesel dan said
if it has no play in turbo
see if a hose has blown off or cut anywhere.
what I do is soapy water in a spray bottle. and spray everything with soapy water.
its all pressurized so it will bubble where it is leaking air.
is it BLACK SMOKING????? that is tall tell sign that a hose popped off.
Old Nov 29, 2009 | 12:12 AM
ok that sounds about right yea i dont know alot about turbos that was jsut a guess, and yes a seal sounds like the possible culprite, and it blacksmokes or it may be like a blueish smoke even at idle?
Old Nov 29, 2009 | 12:46 AM
2500HeavyDuty's Avatar
this is the stock turbo?
Old Nov 29, 2009 | 09:41 AM
black/blue smoke at idle means your burning a little oil with possibly an intake problem which could be caused by the turbo, so i would deff say a seal is leaking.
Old Dec 10, 2009 | 12:06 AM
yes it is the stock turbo and that sounds like a good source to the problem, thanks for the help
avatardvr
18
Aug 8, 2019 12:38 AM
|WYG|SS
Jul 8, 2015 08:39 PM
|WYG|SS
Jul 4, 2015 08:31 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
