problem with front axle
Old Nov 23, 2009 | 10:05 PM
casper83's Avatar
Default problem with front axle
when i engage 4 wheel drive everything works but the front diff, and i know it has to do with the CAD, but where do i start
Old Nov 24, 2009 | 09:35 AM
PhilipR's Avatar
Check all the vac lines for leaks. If no leaks the CAD unit itself is probably at fault. I would just swap it out for the 4x4 posi lock kit and ditch the vac operated system if it's bad.
Old Nov 24, 2009 | 11:39 AM
Yeah, go over your vacume lines with a fine tooth comb.
4x4 Posi-Lok - 4WD Engagement Systems
Old Nov 24, 2009 | 08:41 PM
12valvetater's Avatar
EMS lock outs itll fix that problem forever.
burndiesel
10
Feb 7, 2023 01:15 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
