Shaking like Hell
My 2001 Dodge Ram wobbles like hell around turns at about 50mph its annoying as well. The truck has new shocks new wheel bearings new track bar and sway bar endlinks and the ball joints dont have any play. Any one know what might be the problem. And also the truck eats right front tires. It wears the outside tread fast. I am out of options i had an alignment and everything, anyone with suggestions with what the hell is going on i would greatly appreciate it. Also would bad leaf springs do any of this. The wobble can also be felt throw the steering wheel as well as the whole damn truck. so annoying.
I think he said he replaced all that but it deff sounds like thats the problem maye the tie rod is bent just a little and is causing it to flex while driving what ya need to do is wire tie a video camera up front and rec. it when it happens i did that with my jeep once
well tires being out of balance, whens the last time they were balanced.
what size tires. the larger the tire the more easily they will just become unbalanced. (more mass)
slowing down for turns. can help a bunch on keeping those shoes from wearing in the edges.(not that i would know
steering dampener, shocks? i go thru shocks about 7-12 months. and dont get cheap ones either(another thing i know about)
i have done alot too to fix my steering/tire wearing. i just give up and deal with it now.
)steering dampener, shocks? i go thru shocks about 7-12 months. and dont get cheap ones either(another thing i know about)
Id agree with a lot that is posted so far and to add one I seen this problem with a bad pitman arm, its usuly from the hole getting walloed out, and some one turn your steering wheel w/ truck on the ground and turnd off wile you watch under neath for movement. also check (if 4x4)the collar on you 4x4 is not slighty locked in. jack up one of both front tires and turn them if the front drive shaft turns you have a problem if its a dana 60 or 70 with the air actuated shift fork. but its easy to fix
