codes
Old Nov 22, 2009 | 08:53 PM
DEERE2500's Avatar
Default codes
i got to codes that poped up P0483 fan speed and P2607 intake heater relay
Old Nov 22, 2009 | 09:23 PM
Whit's Avatar
Site Mascot
check yer relays for the grid heaters and see if ya poped one
fan speed ......I dunno
Old Nov 22, 2009 | 09:38 PM
wildbill's Avatar
The P0483 code, turn it over to defrost, and see if the fan kicks in. If not, your fan clutch is burnt out.
P2607, check and clean all the relay connections (be on the passenger side) with electrical contact cleaner. Clean and protect all the battery terminals, along with cleaning all ground points. If the code clears, then returns, it's possibly the relay burnt out. With that, does the volt meter drop right after you start the truck in the morning, then fluctuate back and forth??
Old Nov 22, 2009 | 09:53 PM
DEERE2500's Avatar
it drops and take a lil bit to get back to normal
Old Nov 22, 2009 | 10:17 PM
wildbill's Avatar
Should be 2 relays on the passenger side, close to the battery (06 went to a single relay). One closest to the firewall is the #2 relay. Look for corroded connections, damaged insulation on the wires. You can tear the relay apart and clean the contacts and see if it helps.
Old Nov 23, 2009 | 07:54 AM
DEERE2500's Avatar
i looked and didnt see it, there is my special coolant, vacuum pump and ac condinsor
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
