Battery Corrison
Old Nov 22, 2009 | 07:33 PM
Captn_tyler's Avatar
Default Battery Corrison
I just cleaned these termanials and they all gunked up again. Whats the deal? Charging system doing it? bad batts? (both sides are the same)
Old Nov 22, 2009 | 08:48 PM
mishkaya's Avatar
It's pretty common when the batteries get older and start leaking. I ended up switching to AGM batteries to avoid this very issue.
Old Nov 22, 2009 | 08:50 PM
Ditto. Optima Red Tops ended my corrosion problems.
Those look like the OEM batteries.
Old Nov 22, 2009 | 09:28 PM
Okay... very well, just happy its not the charging system. I heard it can do the same thing
Old Nov 24, 2009 | 10:01 PM
lobsterman04's Avatar
If youd like you can tape some pennies by the terminals and they will attract/minimize the corrosion on the terminals untill you purchase new batts.
Old Nov 24, 2009 | 10:30 PM
Yeah that actually works. And they actually stay in place.
Old Nov 25, 2009 | 10:08 AM
kazairl's Avatar
One word: Vaseline. I slather it on all the battery connections on all my vehicles and I have no corrosion problems.
Old Nov 25, 2009 | 10:51 AM
Jazz's Avatar
Sounds like a pretty cheap fix to help get by. What would that cost a guy $.04? I like it. A mod I can actually afford
Old Nov 25, 2009 | 01:28 PM
Codgedodger's Avatar
FormerVendor
I did that, it works good.
Old Nov 25, 2009 | 02:17 PM
jessy's Avatar
I thought it was 2 per post. I think it’ll cost you 8 cents and they didn’t come with the tape.
