Delivery Valves
Old Nov 22, 2009 | 05:40 PM
hunter's Avatar
Default Delivery Valves
currently running 191s makes good power but considering laser cuts will it make more with my current set up?
any suggestions
Old Nov 23, 2009 | 08:52 AM
PhilipR's Avatar
More smoke and more heat.......
Old Nov 23, 2009 | 09:16 AM
94 12valve's Avatar
I would stay with the 191's and get my self a better set of injectors
Old Nov 23, 2009 | 10:04 AM
Shea@L&N Performance's Avatar
FormerVendor
X3, no need to ever put a set of laser cuts in your truck. Theres no need for excessive smoke and alot more heat. Like 94 said save up for some better injectors
Old Nov 23, 2009 | 01:10 PM
Hammer's Avatar
I would stay with the 191's and get my self a better set of injectors.
X4.........
IMO...Full cuts have no place on the street,power can be made without their use.
Old Nov 23, 2009 | 02:23 PM
94 12valve's Avatar
Originally Posted by Hammer
X4.........
I agree I loved my 191's for the street
Give chris a call @ SDX for a great set of injectors at a sweet price
Old Nov 23, 2009 | 04:01 PM
12vcummins96's Avatar
dont go higher than the 191s lc or fc are to much get a better set of injectors
Old Nov 23, 2009 | 10:15 PM
hunter's Avatar
thanks for the comments do u think they would help for the dyno
Old Nov 24, 2009 | 05:55 AM
94 12valve's Avatar
yes
Old Nov 24, 2009 | 10:35 AM
Hammer's Avatar
Yes...
IF you were keeping a log of what changes you make or made the day you dyno so you know what or how you had everything set up to fall back on.I keep a log book on mine and have since day 1 and can show you everychange I made and what worked that day and what didn't.I learned that when I was racing my superstocker as it helped to dial the car at diffeent tracks and helped when you needed a hundreth or two in a heads-up class race.
The tune with full cuts will be alot different on the dyno than the 191's as they will overfuel down low and could put the fire out killing your attempt at any big HP number.Thus the reason for logging what you do so you have a way to fall back and get yourself close for the show that day......Andy
