Fuel pressure guages.
Old Nov 21, 2009 | 09:41 PM
DieselPerformanceGuy's Avatar
Default Fuel pressure guages.
Hey all,
i am getting a new fuel pump soon and i was wondering if this gauge will work for the first gens, and if anybody has this gauge any input would be great.
http://www.genosgarage.com/prodinfo.asp?number=AM-4360 UL
thanks all.
sorry about that the guage didn't come up so go to guages, autometer, and it's the ultralite electric fuel psi guage 30 psi.
Last edited by DieselPerformanceGuy; Nov 21, 2009 at 09:42 PM. Reason: Automerged Doublepost
Old Nov 21, 2009 | 09:50 PM
Richie O's Avatar
Try this link. Is this the one?
http://www.genosgarage.com/prodinfo....r=AM-4360%20UL
Old Nov 22, 2009 | 01:31 PM
yep thats the one i was asking about, do you know if it will be a direct fit if it even works.
Old Nov 22, 2009 | 02:56 PM
muskrat's Avatar
Yes, it should work, with the right install hardware, which I think you need to purchase aside from the gauge. Just a thought, here. Go to the sticky and open the fuel gauge install thread and check out that set up. It litteraly took me 20 minutes to install and that whole kit is almost half the price of the gauge you're looking at.
Old Nov 22, 2009 | 03:39 PM
Richie O's Avatar
Not sure on this specific gauge , but I ordered a isspro from genos and the kit came with everyting needed. Mine is mec. but came with the isolator and all the tubing. I would call for sure before ordering. I have had good service from geno's, e gauges.com, and also bought from isspro direct. I have autometers in the 89 ( pryo and boost ). Happy with those also.
Old Nov 22, 2009 | 06:31 PM
alright thanks guys!
richie o
is this the same gauge as urs just white, and did ur kit have all the same lines and regulator.
https://www.dieselbombers.com/1st-ge...e-install.html
Last edited by DieselPerformanceGuy; Nov 22, 2009 at 06:31 PM. Reason: Automerged Doublepost
Old Nov 22, 2009 | 07:38 PM
Richie O's Avatar
Looks the same. Now that I think about it, mine did not come with the rubber line. I just used a piece of rubber marine fuel line to go from banjo to isolator. I also plummed in a snubber incase I had gauge flutter. I do not have flutter so the snubber is wide open.
Old Nov 22, 2009 | 07:41 PM
in genos the exact gauge ur talking about says it has an isolator and 8ft of rubber fuel line.
Old Nov 22, 2009 | 08:04 PM
Richie O's Avatar
It says 8 ft of tubing. Thats the little plastic line that goes from isolator to gauge.
http://www.genosgarage.com/prodinfo....ber=ISS-R5604R
Old Nov 22, 2009 | 09:24 PM
o so i would have to buy the fuel line and that fitting, am i missing anything else.
so then will this kit work.
http://www.genosgarage.com/prodinfo....mber=VULCAN-FH
Last edited by DieselPerformanceGuy; Nov 22, 2009 at 09:24 PM. Reason: Automerged Doublepost
