Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
where is the wastegate
Old Nov 21, 2009 | 04:21 PM
ROLLIN ON 37s's Avatar
Default where is the wastegate
i seen that bullybog has a boostvalve or wastegate for my lly. i was just curious on where that is located on my engine? any ideas? thank you
Old Nov 21, 2009 | 06:24 PM
jlawles2's Avatar
Stock LLY does not use a wastegate. Instead it used a variable vane turbo.
Old Nov 21, 2009 | 06:31 PM
2500HeavyDuty's Avatar
the lly turbo does not have a wastegate, it uses the vaines inside the VGT to moderate the exhaust drive pressure produce the desired boost.
Old Nov 23, 2009 | 01:43 PM
oh ok. i was just checking. i seen one on dmaxstore.com and was curious. thank you
Old Jan 16, 2010 | 02:28 AM
dirty_d_max's Avatar
if you are wanting to up your boost PPE sells the electric boost controller, kinda spendy but it'll lower your egt's a bit when you're towing or on a hot tune
bigblu
18
May 10, 2015 10:52 AM
daniel2500
Apr 27, 2015 06:04 AM
wpg6.5
Feb 19, 2015 07:27 PM
