Put pot in my 91 and still no OD
Old Nov 20, 2009 | 05:21 PM
Diesel power's Avatar
Default Put pot in my 91 and still no OD
I put the Potentionmeter in my 1991 D-350 and still has no OD. What could it be?
Old Nov 20, 2009 | 11:42 PM
big bad diesel 416's Avatar
Site Sponsor
screw it and put it on a toggle
Old Nov 21, 2009 | 02:40 PM
witch wiers do where?
Old Nov 21, 2009 | 08:23 PM
Site Sponsor
i believe its just a solenoid on and off some one knows they have done it before
Old Nov 21, 2009 | 08:26 PM
12vcummins96's Avatar
it is the three wire switch on the driver side of the tranny it is black with a orange stripe add a ground to that through a switch and bam lock up
Old Nov 21, 2009 | 10:13 PM
RSWORDS's Avatar
No lock up on the 1st gen OD trannys... On the 1st gen trannys its only two wire also. I BELIEVE its the rear wire. Find which one has power when the truck is running and set the toggle switch up to ground the other when you want OD.
Old Nov 22, 2009 | 04:07 PM
thanks alot il give that a try.
Old Nov 22, 2009 | 04:25 PM
muskrat's Avatar
Here are a couple links that might help.
http://www.dieseltruckresource.com/d....html?t=142641
http://www.dieseltruckresource.com/d....html?t=156988
Old Nov 22, 2009 | 05:42 PM
I checked the wire and it shows 12volts is that to high?
Old Nov 22, 2009 | 08:26 PM
RSWORDS's Avatar
what wire?
The harness going into the tranny should have one wire at 12v all the time and the other wire gets grounded out when you want OD.
