More problems with my Truck
Old Nov 20, 2009 | 12:35 AM
Tweaker727's Avatar
Default More problems with my Truck
Long story short i'm starting to have some " Surging / Bucking " issues in my truck.
I've know these transmissions to have " Gov. Trans deucer & and pressure solenoid " issues
I an luck enough to be able to use a local transmisson shop's scan tool and got some info from the owner.
The Desired pressure was about 2X what the trans was actually putting out. Which he said indicated a bad solenoid setup in it.
But at the same time i pulled 3 codes,
P0500 Vehicle Speed Sensor Malfunction (Always had it, never goes away)
P0122 Throttle Position Sensor/Switch A Circuit Low Input
And one that is partially my fault cause i drove the truck some 75 miles with the fuel gauge on E
P0460 Fuel Level Sensor Circuit Malfunction (Scan tool said " No Change over long distance "
So i'm not sure where to go besides resetting the APPS sensor with the battery disconnect method
Any other ideas ? I'm about as broke as they come for now. so cheap cheap is my only option for now !
Thanks for the help
Nick
Old Nov 20, 2009 | 12:37 AM
Check the Voltage on your APPS.
Old Nov 20, 2009 | 01:12 AM
blkjack's Avatar
Sounds to me like the apps is needing replaced was just discussing this in another thread last night i orderd one this morn the run about 400$ through the stealer but there is a aftermarket one made by timbos apps run 160$ i feel your pain with the budget im in the same boat but tired of mine surgin. I have a 6spd in mine but i think seeing the tps low voltage code there is a open in the apps causing a drop in voltage and the puter isnt liking that so the motor surges and throws a code. This is the direction that im heading in replace the apps i will try to find the thread and post a link has all the guys order info and web site n stuff.
Here is the link to the site for those apps Contact Us
Check it out see what you think
A thanks to Jazz for that link. I couldnt figure out how to link back to his post.
Stupid computer illiteracy gets me every time
Old Nov 20, 2009 | 09:12 AM
ja-mudder's Avatar
Go to rock auto for a air tex full apps bracket and sensor there under emishion controll and if you want to chance it blue chip for just the sensor i just got an air tex and its all good now as far as that goes
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
kalarachelle
Feb 21, 2015 03:25 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
