Wtb Wastgated H1c
Old Nov 19, 2009 | 08:29 AM
1stgenjunkie's Avatar
Default Wtb Wastgated H1c
I am looking for a wastgated H1c, Would like to find a cheap one that might need rebuilt. or a good usable one for the right price. Thanks
Old Nov 19, 2009 | 09:47 AM
NadirPoint's Avatar
early 2nd Gens were the only H1Cs that came WGt'd - WH1C. You can get a WG'd turbine housing to bolt on any H1C, tho. If I was you, I'd just go with a bigger turbo for those PODs. The small turbos are barely adequate for stock fueling with a turned up pump and fuel pin/AFC mods.
Old Nov 19, 2009 | 10:30 AM
im building twins, thats the need for the wastgated H1. I have an Hx35 but only has a 12cm housing need at least a 14cm housing.
Old Nov 19, 2009 | 11:02 AM
93rollincoal's Avatar
Default want more power for my 1st gen
i need help with my new truck 1993 12 valve i want to turn up the pump and slide the plate but dont know how any advice or help is appreciated
Old Nov 19, 2009 | 11:27 AM
NadirPoint's Avatar
But anyways, go over this then start a new thread with a specific question...
Turning up the pre 94 Ram diesel injector pump
Old Nov 19, 2009 | 01:57 PM
Not tryin to be a D$%C, but what does that have to do with a wastgated H1c?
Old Nov 20, 2009 | 11:36 AM
93_Fummins's Avatar
Just out of curiousity, why do you need a 14cm housing instead of a 12cm housing? Won't the 12cm spool it faster which is what you want with the small charger in twins? I'm looking at twins in the near future, so I'm still taking notes...
Old Nov 23, 2009 | 06:44 AM
Yes a 12cm will spool faster but you will also loose some top end power, witch is were im tryin to find a happy median. Between low rpm power and high rpm power
Old Dec 14, 2009 | 10:09 AM
Diesel Nut's Avatar
I have a low mileage WH1C on the turbo shelf. 19k miles on it. Give me a call and we'll see what we can do.
scottw1513
Wanted To Buy (WTB) - Used
Dec 22, 2015 12:08 AM
12valveblackcloud
Jun 5, 2015 10:12 AM
savage87
May 31, 2015 12:39 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
countryboy040993
8
Nov 1, 2014 04:00 PM
