NV241 HD transfer case question
Old Nov 19, 2009 | 02:28 AM
dieseldocter16's Avatar
Default NV241 HD transfer case question
So i finally started dismantleing my truck tonight starting the auto to manual swap and when i removed the transfer case there was a plug on the top with a bunch of little rubber hoses. What are these hoses for?
Old Nov 19, 2009 | 02:52 AM
nate379's Avatar
It's a vac switch to engage the front axle on the 2001 and older trucks.
Old Nov 19, 2009 | 10:15 AM
Then what are the 2 hard lines that run from the t-case across the crossmember along the frame up to the front axle?
Old Nov 19, 2009 | 12:39 PM
blkjack's Avatar
Those are are the vac lines that engage the 4x actuator on the axle to lock the front axles together for 4x4
Old Nov 19, 2009 | 11:53 PM
Ok thanks!
Old Nov 20, 2009 | 02:23 PM
crazycooter's Avatar
oh and by the way, if they come disconnected while driving, it engages your front end and you can wear out your front driveline pretty quick. yes it sucks.
Old Nov 20, 2009 | 04:47 PM
nate379's Avatar
The only way the axle is going to lock in is if there is vacuum applies to one side of the actuator, or I suppose pressure applied to the other side. If you just unplug it (or it came off) it wouldn't do anything.
Or.. if you ran the truck in 4x4 and the vac line to the axle undid. It would run in 2wd at the T Case, but the front end would be engaged still. It's not really a big deal, most all the late 80 to early 2000 Jeeps have the front end locked all the time. The 01-02 2500/3500 same way.
Old Nov 20, 2009 | 10:25 PM
ja-mudder's Avatar
This is most of the way right
the vacume on these 4x4 front axle require air suction to move it around SO if your in 2x4 and it came off nothing would happen other than it would not go into 4x4 and its the same the other way around because the suction comes from the other side to slide it in to 4x4. i only know cause the shavt on my air actuator was bent and i went through everything under there
Old Nov 21, 2009 | 11:48 AM
nate379's Avatar
Right, that is exactly what I said.
the vacume on these 4x4 front axle require air suction to move it around SO if your in 4x2 and it came off nothing would happen other than it would not go into 4x4 and its the same the other way around because the suction comes from the other side to slide it in to 4x4. i only know cause the shavt on my air actuator was bent and i went through everything under there
Old Nov 21, 2009 | 12:34 PM
Thanks for the info.
dezeldoc
Wanted To Buy (WTB) - Used
Jan 27, 2016 05:08 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
