Smoking too much?
Old Nov 18, 2009 | 06:58 PM
texas503's Avatar
Default Smoking too much?
My truck just recently had a new injection pump put on but it seems to smoke alot compareds to other 24v I see and alot more than my buddy's. It has an Edge Comp without the pump tapped and when I go into lockup it will just smoke out black smoke. It will also puff out a large cloud of black smoke when I let out of it after WOT. I have hit 22 PSI of boost at WOT but have a hard time getting over 15 PSI, and yes I do have an adjustable boost elbow. Any ideas, the truck runs fine but would like to actually get power out the that unburnt fuel. Could it be injectors? Thanks
Old Nov 18, 2009 | 08:26 PM
94dizzyram's Avatar
Possibly a loose or torn boot. Just a thought.
Old Nov 18, 2009 | 08:41 PM
coyropin's Avatar
check the easy stuff first air cleaner filter is it dirty. check your wastgate does it move up and down ok. check your air to air boots like dizzyram said they rub on the lower p/s if your not sure you can build a tester kit
https://www.dieselbombers.com/24-val...ke-system.html
https://www.dieselbombers.com/dodge-...tructions.html
here are some ways of making them cheap and easy to do start there and see
Old Nov 18, 2009 | 08:58 PM
Check for boost leaks or you might have a set of injectors in there.
Old Nov 18, 2009 | 09:44 PM
Shea@L&N Performance's Avatar
FormerVendor
Do what the other guys said, sounds like you got a boost leak beacause you should be gettin more boost than that.
Old Nov 18, 2009 | 10:11 PM
blkjack's Avatar
I have been lookin on here for those testers i just bought some parts the other day to check mine this weekend but now seeing those testers gives me some differnt ideas on buildin mine thanks for the post guys good info there im thinkin i got some leaks too not smokin and dont have a gauge but doesnt feel like it is building boost like it should and kinda hesitant at times but fuel lpress is ok so gonna start there
Old Nov 18, 2009 | 11:36 PM
texas503's Avatar
So it sounds like a boost leak? Is there any posssiblity that an injector is sticking open a little? I don't want to wash a cylinder. I am sure it doesn't have after market injectors because it doesn't seem to have an over abudance of power.
Old Nov 22, 2009 | 02:27 PM
texas503's Avatar
Just to clarify the truck smokes during low boost situations also and it does not have as much power, especially when pulling as I think it should. It won't hold 65mph pulling 5-6k lbs. I have to hit 70+ for it to hold on a hill, if I get below 70mph then my speed rapidly decreases.
Old Nov 29, 2009 | 08:20 PM
texas503's Avatar
Well I built a boost tester and found a couple of leaks, one at a clamp and two very small leaks where there is a tiny hole in a boot. But I can't get the system to stay pressurized. I can hear a leak, and I don't know if it is a valve letting air out. I hear the leak on passenger side of motor and can seem to hear it louder from under the truck. I bumped the starter to try and rotate valves, but with no success. Any ideas? Is there any other way to cycle motor without the starter? Thanks
Curry
Apr 20, 2015 04:04 AM
NaturesPace
Dec 16, 2014 12:01 AM
nathan.kelley
Nov 15, 2014 01:11 PM
CO TOM
Oct 24, 2014 11:33 PM
CO TOM
Oct 16, 2014 09:55 AM
