vehicle speed sensor question
Old Nov 19, 2009 | 05:30 PM
tltruckparts's Avatar
Default vehicle speed sensor and electric vacuum sensor question
on a 93 cummins 4wd auto trans, ont he np205 is the speed sensor. my question is does anyone know how many pulses per mile the speed sensors put out for the electric speedo? thanks
and also on alldata im wiring something up and it says one of my connectors goes through an electric vacuum sensor. anyone know what or where this is. i cant find it anywhere
anyone?
Last edited by tltruckparts; Nov 19, 2009 at 05:30 PM. Reason: Automerged Doublepost
Old Nov 19, 2009 | 06:10 PM
Jet A Fuel's Avatar
The only way I can think to find this out is count the number of teeth on the phonic wheel and take that number.
Then find out how many revolutions the output shaft makes in a mile with the stock size tire. To find this out take the circumference of the stock tire and divide into 5280.Then take your gear ratio in the rear end and devide the tire rotation number.then you will know how many times the output shaft spins in one mile.
each tooth on the wheel should be a pulse.
Hope this is correct I am no mathmatician.
Old Nov 19, 2009 | 06:18 PM
ya thats alot of work just for a spec . im hoping someone knows so i dont have to take it to a speedo shop to get it to work
Old Nov 20, 2009 | 07:31 PM
someone has gotta know the answer to one of these two questions
Aug 27, 2015 05:50 AM
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
Oct 27, 2014 08:10 AM
