Speedo Adjustment
Old Nov 17, 2009 | 11:41 AM
PhilipR's Avatar
Default Speedo Adjustment
Since I am running 285's on my truck my speedo is off. i know about the superlift box but I'd rather not splice wires. Can a good scanner that streams live data change this or do i need to go to the stealer?
Old Nov 17, 2009 | 05:33 PM
Hammer's Avatar
Only way to change the speedo on the older 12v trucks is to switch out the gear in the transmission that I know of.With 285's the speedo is not off all that much unless you a stickler for detail I'd just drive it.........Andy
Old Nov 17, 2009 | 05:49 PM
Should be out ~7% with 285's
Old Nov 18, 2009 | 05:46 AM
PhilipR's Avatar
There is no speedo gear. That would be easy if it was. Mine gets the speedo reading off the VSS on the rear diff. I would like it fixed because the VSS sends signals to the PCM for trans shifting.
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
2gCummins
Jul 22, 2015 11:34 PM
Cutlass26
Mar 22, 2015 05:46 PM
iamgizmo
Feb 6, 2015 08:48 PM
marks86
Oct 23, 2014 03:25 PM
