fuel system
Old Nov 17, 2009 | 09:11 AM
91 12valve's Avatar
Default fuel system
with pump tweaked a little should i need a fuel system before injectors i would like to get at least 80 horse or will i be ok with factory lift pump
Old Nov 17, 2009 | 09:13 AM
Budgreen's Avatar
A low pressure piston lift pump seems to be a recommended upgrade. The only real way to know is to get a fuel pressure gauge and keep an eye on it.
Old Nov 17, 2009 | 09:19 AM
91 12valve's Avatar
i guess factory my lift pump is in the tank right
or would the airdog system be much of a price difference
Last edited by 91 12valve; Nov 17, 2009 at 09:19 AM. Reason: Automerged Doublepost
Old Nov 17, 2009 | 09:20 AM
Budgreen's Avatar
Factory lift pump is on the side of the motor, mechanical like the older gasser motors.
Airdog would be a bit more pricey than the mechanical upgrade but it's a LOT better system.
Old Nov 17, 2009 | 08:06 PM
91 12valve's Avatar
thanks for the info i will have to look into a low pressure piston pump
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
