6.0 wierd noise
Old Nov 17, 2009 | 07:38 AM
Heavy's Avatar
Default 6.0 wierd noise
Anytime you push or let of the throttle it has a wierd whistle and I cant seem to figure out what it is it is definitly not turbo wine it start out only happening a couple times but now it is all the time.Any advise woould be great thanks
Old Nov 17, 2009 | 05:01 PM
scrotom's Avatar
mine did that and it was the head gaskets. pressure coming out of degas cap.
Old Nov 17, 2009 | 06:43 PM
bobfbigman's Avatar
The noise could also be a cracked ypipe, if you stand outside the truck and start it does it sound normal for the fist few seconds and then you hear the hiss come from under the hood?? that is what mine did and it was the y pipe that feeds the turbo, open the hood and see if you smell diesel exhaust, mine was pretty strong. Bob
Old Nov 18, 2009 | 09:38 AM
Heavy's Avatar
No i dont smell any exhaust under the hood and there is no noise at all when its idleing it is only between 10 and 20 psi of boost
Head gaskets yea that sounds like fun thanx for the info
Old Nov 22, 2009 | 09:00 AM
Big Angry Hillbilly's Avatar
Sounds like you might have a split CAC tube or intercooler leaking, if it's only happening at higher boost.
Old Nov 23, 2009 | 11:34 AM
Heavy's Avatar
well it ended up being a head gasket and now trading it in on the 6.4 thanx for the help
Kbnecessary
May 28, 2015 10:51 AM
scubasteve12
Mar 29, 2015 09:39 PM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
