Hollowing out the dpf?
Old Nov 16, 2009 | 07:19 PM
tyrel_44's Avatar
Default Hollowing out the dpf?
Can the dpf be taken off, hollowed out and reinstalled as a dpf delete? I know I'd have to run a smarty or another programer to make it work.. It would probably be easier to just buy a delete kit but I'd like to keep the stock apearance in case they start checking for these here in OK. Is there anyone who has done this?
Old Nov 16, 2009 | 07:26 PM
wildbill's Avatar
This is pretty much what's inside of them. This is from an old converter off my 06.
Old Nov 16, 2009 | 07:27 PM
wildbill's Avatar
But yeah, you can hollow em out and reinstall the housing.
Old Nov 16, 2009 | 07:36 PM
tyrel_44's Avatar
Does it sound ok after this is done? I mean does it sound like a regular CR?
Old Nov 16, 2009 | 07:41 PM
wildbill's Avatar
Well, here's what my 06 sounds like without a cat, and with an Aeroturbine.
Old Nov 16, 2009 | 08:12 PM
ShaneMSnyder's Avatar
You'll get a lot more whistle from the turbo for sure, especially with the EB on and a cold start. I've only seen people weld some piping for a straight through design when hollowing it out. I'd just get a delete pipe or make one. That DPF is an expensive piece of.....junk...
Old Jan 6, 2010 | 07:07 PM
smart6.7y's Avatar
next time you do a cold start and turn on the eb. put your truck on a high idle using the crusie control.. It sounds sick!!
Old Feb 8, 2010 | 12:00 PM
puller451's Avatar
How do you use the cruise to put it on high idle?
Old Feb 8, 2010 | 09:09 PM
R&RDiesel's Avatar
FormerVendor
If its a manual, put it in neutral and put the parking brake on. turn on cruise control and hit the set button, should go to about 1100-1200 rpms.
If an auto put it in park and do the same thing.
Old Feb 10, 2010 | 09:37 AM
FarmDiesel's Avatar
My manual doesnt do it, and the dealership says they cant set it up to do it.
