Adam's Polishes Visit - Adam's Polishes
NEW! Adam's Hex Grip Polish Applicators - 3PK
Old Nov 16, 2009 | 12:54 PM
Nitelord's Avatar
Default NEW! Adam's Hex Grip Polish Applicators - 3PK
Adam's Premium Hex-Grip Foam Polish Applicators
Orange: Swirl & Haze Remover
Blue: Revive Fine Hand Polish
Red: Buttery Wax or Machine SuperWax, our polymer sealant
Some people only want to polish and wax by hand, and have no interest in machine polishing! They want to feel every curve of the body panel, both applying and removing polish and wax. Are we talking about you? This is your applicator.
The ORANGE Hex Grip Applicator features the same German Durafoam that our Generation 2 Machine Polishing Pads use, and is for use with our Swirl & Haze Remover.
The BLUE Hex Grip Applicator features FINE GRADE foam, designed specifically for use with our Revive Hand Polish.
Our RED Hex Grip Applicator features fine foam, for waxing with our Buttery Liquid Hand Wax, or, our Polymer Sealant, the Machine SuperWax.
With this applicator, you will hand polish more effectively, and accomplish staggering results.
These sturdy Hex Grip applicators are ergonomically designed to be the most comfortable on the market. Guaranteed 110% to out-perform any applicator on earth.
Instructions for Use:
1. Clean Vehicle
2. Use the Clay Bar and Detail Spray to remove surface contamination.
3. If the vehicle has visible swirl marks in broad daylight, you will want to use our Swirl & Haze Remover & Orange Swirl Killer Hex Applicator Pad.
4. If your vehicle as minor swirls, only visible under garage or florescent lights, Proceed with the following steps:
5. Spray a very light mist of Detail Spray to the face of the Hex Grip Applicator.
6. Apply a dime-sized dab of Revive Fine Hand Polish to the Blue face of the Hex Applicator pad.
7. Apply a fine layer of Revive Polish to the finish, avoiding the cracks and emblems.
8. Finish vehicle, then remove residue with our Super Plush Polishing Towel.
9. Follow with protection, such as Buttery Liquid Hand Wax, Americana Premium Paste Wax for a Concours gloss, or for cars parked outdoors day or night, our Polymer Sealant, Machine SuperWax.
Hex Grip Applicator Cleaning Instructions:
1. For best results, clean after each use!
2. Spray Hex Grip Applicator with our All Purpose Cleaner.
3. Squeeze the applicator in half, then spray more APC into the face.
4. Work the cleaner evenly into the blue face of the applicator.
4. Rinse with water.
5. Squeeze out the water, then allow to dry for 48 hours between uses.
Take hand polishing to the next level with Adam's Hex Grip Premium Foam Polish Applicators!
Old Nov 16, 2009 | 02:32 PM
busta's Avatar
gonna have to check them out when i get some cash
the adams products that I have so far have exceeded my expectations of them
the new applicators will make them even easier to use
Old Nov 16, 2009 | 09:06 PM
Nitelord's Avatar
Thanks Kevin. They really do reduce the stress on your fingers, hands and wrists.
Anything to make life easier...
Old Nov 17, 2009 | 08:13 PM
turbo20psi's Avatar
Im going to buy some of those,mostly for the aircrafts and the truck to.
