Diesel Related Events Post All Diesel Related Event Information, Dates and Results Here - Includes Racing, Pulling, Dyno ect... All Local, State and National Event Information
*POST AND DISCUSS ALL DIESEL RELATED EVENTS HERE*
truck pull covington TN dec,5th
Old Nov 15, 2009 | 10:33 PM
need help 6.7's Avatar
Default truck pull covington TN dec,5th
dyno and truck pull in covington tn hwy 51 there will be multiple classes for both
Old Nov 27, 2009 | 02:38 PM
bigmax53's Avatar
didn't see what classes etc.. and is it indoor or out
Old Nov 27, 2009 | 09:43 PM
There will be 4 diesel classes and rules are posted at midsouthdieselpullers.com thanks hope to see you there
Truck Pull Classes
Gas Class- Street legal gas truck. Anything goes but must be street legal.
Stock Diesel Class- Stock Turbo, Aftermarket Intake, Exhaust and Programming allowed, no visible performance modifications other than intake and exhaust. Maximum Weight 8500 lbs
Diesel Class 2- Stock turbo, Fuel system modifications allowed, hanging weights allowed, Max weight 8500 lbs
Diesel Class 3- Aftermarket Turbos, hanging weights allowed, maximum weight 9000lbs
Diesel Class 4- Anything goes, nitrous, propane, water methanol, no weight limit
Rules
·First Puller in each class gets the option to re-pull
·1” Suspension travel in all classes except Diesel 4
·If you break a drive shaft and you don’t have u-joint shields your pull is disqualified. If you break a drive shaft and you have shields your pull counts.
·If your hitch breaks you are disqualified
·If you are unable to drive the truck off the track you are disqualified
·If you have not reached 75ft. you may back up and start over one time.
·All tires must be DOT legal uncut
·Exhaust must exit behind the cab in all classes except Diesel 4
·The three members of the tech staff will address anything the tech staff finds unsafe or unfair. Three tech staff members will be present on each tech inspection.
·Nitrous, Propane, Water-methanol allowed only in Diesel class 4
·If a truck is over 8500 lbs. in the stock diesel class the tech staff has the option to let them pull if no weight has been added. Don’t show up with a full tank of diesel and be over 8500 and expect to pull
Last edited by need help 6.7; Nov 27, 2009 at 09:43 PM. Reason: Automerged Doublepost
Old Nov 28, 2009 | 08:14 AM
bigmax53's Avatar
thanks for info building new truck and need as many hooks as I can get before next year.
Old Dec 22, 2009 | 09:29 PM
hunter's Avatar
i hate that i just found thiswhere is hw51 in relation to nashville and when is the next pull
Pulling promotions
Sep 18, 2015 01:39 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
