91 D-350 has no od
Old Nov 14, 2009 | 03:38 PM
Diesel power's Avatar
Default 91 D-350 has no od
my 91 dodge lost od then came back and lost it agen this went on for a month then lost it all together. did the test to the t.p.s it was not working so went and got a loan of one that put ot the proper volts but sitll no od. what could it be?
Old Dec 9, 2010 | 06:06 PM
would a valve body make my tranmisson not go into od?
Old Dec 9, 2010 | 06:46 PM
moneyman_09's Avatar
Is your truck 4wd?
Old Dec 9, 2010 | 07:26 PM
kieron_kohlmann's Avatar
you tested the TPS. what about a wire to the TPS?
Old Dec 9, 2010 | 07:30 PM
If it's 4x4 the sensor on the transfer case can come loose and cause your speedometer and od not to work. I had had mine fall off before
Old Dec 13, 2010 | 11:24 AM
its not a 4x4 and i have no tps on it i have a togle switch on it.
Old Dec 13, 2010 | 10:48 PM
CaseyF's Avatar
So if you put the toggle switch on it, you can take the TPS off? Just asking because I had to put a toggle on it.
Old Jan 5, 2011 | 03:35 PM
i did and it has been working for over a year.
would a spring be week or broke and not let it go into od??
Old Jan 14, 2011 | 05:47 PM
rab475's Avatar
itsw the silienoid in the valve body no big deal i had one do the same and cost less than $100 to have it fixed
Old Jan 19, 2011 | 09:59 AM
i tested the silienoid and it works, would it be weak?
SkiDooGuy
Sep 9, 2015 05:55 PM
Agapito
Jun 14, 2015 01:32 PM
BuBBa 85
May 30, 2015 04:54 PM
#cummapart
May 5, 2015 12:54 PM
twinboys
Feb 18, 2015 06:55 PM
