Iam lost
Old Nov 14, 2009 | 08:45 AM
big_dog37074's Avatar
Default Iam lost
When I have my lights on, and I get on it my truck real hard my lights start to flicker. I had the alt rebuild. batterys are good check all my grounds and positives. has anyone had this problem before
Old Nov 14, 2009 | 08:50 AM
wildbill's Avatar
What does your volt gauge do?? Could be the PCM, or lamp switch.
Old Nov 14, 2009 | 06:29 PM
Well most of the time its alittle over 14, But sometimes it goes under 14 not much maybe 13. Thats what I was thinking was pcm.
Old Nov 14, 2009 | 06:31 PM
Whit's Avatar
Site Mascot
this is odd
Old Nov 14, 2009 | 06:33 PM
wildbill's Avatar
I can't remember where it's located exactly, but it's on the passenger side, somewhere around the firewall. When you find it, see if the connection is dirty.
Old Nov 14, 2009 | 06:43 PM
b.lee's Avatar
The headlight switch is cheap and very easy to change.
(If cleaning the PCM connections doesn't help)
I've had to replace my headlight switch 3 times
Once in my old 95 1500 gasser
And Twice in my 96 2500 CTD
The trailer lights pull thru that headlight switch from the factory. (If your truck didn't come with the OEM trailer wiring installed, most didn't, mine didn't even have a Reese hitch on it) There is a fix for this, running your wiring off the OEM harness under the drivers side door / bottom of the firewall area. I did and now no more headlight switch problems.
Not saying this is your problem, but it might help.
Old Nov 14, 2009 | 08:46 PM
Thanks, Iam going to try cleaning it. if that doesnt work iam going to replace the light switch. Then go from there
Old Nov 15, 2009 | 12:05 AM
Hammer's Avatar
Doesn't do it until he mashes on it eh...
Follow the positive battery cable on the drivers side down to the starter.There is a point where it is held in place by the oil pan bolts and many times it will wear and intermittently make contact thus creating a quick short or discharge of the charging system.This is more prone to happen when your under heavy acceleration and the motor torques over due to the normal rotation of the motor.That cable is a known problem and I have seen it fail alot and need replaced.Not syaing its your issue but its certainly worth a looky see.........Andy
Old Nov 15, 2009 | 10:06 AM
12vcummins96's Avatar
very good observation i had that problem real easy fix
Old Nov 15, 2009 | 10:24 PM
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
bigd.t
Jun 17, 2015 02:16 PM
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
alex74708
Dec 18, 2014 07:54 PM
4estlee
Oct 7, 2014 07:47 PM
