questions about fuel filter canister?
Old Nov 13, 2009 | 11:03 PM
98dodgecummins's Avatar
Default questions about fuel filter canister?
hello today i been driving and i noticed that my fuel canister was leaking. where it is leaking is on top. there are to bolts on the top and then their is a plug with wires coming out of it. the plug with wires connected is where it is leaking it is leaking around the seal of it if someone could tell me what to do or how to fix it i would appreciate it.
Old Nov 13, 2009 | 11:55 PM
I assume this is a 24V??
Please post in the correct forum.
Old Nov 14, 2009 | 08:24 AM
yes it is a 24 valve.
Old Nov 14, 2009 | 08:39 AM
Whit's Avatar
Site Mascot
that is the fuel heater.......................get a new o-ring for it, lube it up when ya install and it will be fine
Old Nov 14, 2009 | 12:10 PM
Hard to tell from your description. Have you ran bio ? Bio is hard on the rubber parts.
I would suspect its the sealing washers on the banjo bolts. They are a special metal washer with rubber on them.
http://www.vulcanperformance.com/category-s/191.htm
Old Nov 14, 2009 | 12:12 PM
Edit - sounds like its leaking from the water in fuel sensor. I would remove it clean the threads and cannister good and goop it up with some Number 2 Permatex, then reinstall. Keep as much Permatex out of the filter canister as possible.
Old Nov 14, 2009 | 09:53 PM
yeah that told me everything but the only spot it is leaking is at the fuel sensor so just need knew o ring what kind of o ring.
The black plug with the two wires is where it is leaking. How do you take this out?
Last edited by 98dodgecummins; Nov 14, 2009 at 09:53 PM. Reason: Automerged Doublepost
Old Feb 2, 2010 | 07:50 PM
fenceman's Avatar
Did you ever fix this problem i have the same problem?
Old Feb 2, 2010 | 08:16 PM
yes i fixed the problem.
Old Dec 2, 2010 | 06:01 PM
J.schiller's Avatar
Default Fuel canister heater senor leak
My dodge just strated this how did you fix it?
Thanks john
