starter
Old Nov 13, 2009 | 06:28 PM
tower_ofpower's Avatar
Default starter
i'm in the market for a starter... looking for someplace with the most reliable and best priced starters. also do the years of these starters cross at all? like is the 89 the same as say a 94?
Old Nov 13, 2009 | 06:41 PM
mishkaya's Avatar
Is yours beyond being repaired? I would suggest a rebuild kit from fostertruck otherwise. Cheap and does the job well.
LarryB's Dodge starting problems solved here.
Good luck.
Old Nov 13, 2009 | 06:53 PM
well i'm sure the contacts arent healthy but this goes beyond the contacts. i believe the armature is grounding out against the magnets from time to time... sometimes it works fine; other times it'll grunt and even stall. it doesnt show any symptoms of it being the contacts... like rapid clicking or sticking. i know the history of the truck... it just needs to be replaced as the fuel shut off wire was loose and they'd crank on the truck until they gave up... sometimes two to 3 tries for up to a minute
according to the denso site the OEM part numbers match from 1989 to 2001 but cross referencing numbers are different
screw it... ordering a 2nd gen starter from summit. tired of my truck being on near death
Last edited by tower_ofpower; Nov 13, 2009 at 06:53 PM. Reason: Automerged Doublepost
Old Nov 13, 2009 | 06:54 PM
mishkaya's Avatar
It would seem that 89 to 93 are the same and after that they are different. Sorry I don't know where to get one cheap. I know where to get a REAL GOOD one though.
Mean Green Starters and Altenators - Mean Green is the manufacturer of Gear Reduction Starters, Altenators, Stainless Steel Receiver Hitches and Jeep TJ Dual Battery Trays.
Hope someone else will chime in to point you in the right direction. And BTW, foster truck does sell NEW Denso starters.
Old Nov 13, 2009 | 06:55 PM
12vcummins96's Avatar
there you go got the same starter from summit love it
Old Nov 14, 2009 | 02:04 PM
RSWORDS's Avatar
As far As I Know they are not the same.
Best price/warenty I found was at Autozone
Also try RockAuto.com
Old Nov 14, 2009 | 05:59 PM
ahhhh crap... if you're right bobby i'm going to kick my self in the *****. like i stated before i got on the nippen denso site and the OEM part number matches from 89 to 01; although the cross refernce and aftermarket numbers do not match. i'm praying they're the same. the 94-01 starters are slightly less powerful than the 89's but that's b/c of the gear reduction. only thingi can see being different would be wire hook ups but i'm pretty resourceful i'll let ya know if it does work and let ya in on how satisfied i am with it... should be a pretty nice upgrade as they dont offer much of anything better than OEM generic name stuff for the first gens
Old Nov 19, 2009 | 10:05 PM
note to self... kick myself in the *****
so just b/c OEM numbers match deffinately doesnt mean they're the same apparently. the new one will bolt up by 2 bolts. 3rd one doesnt line up. and the off-set is about 1/8th of an inch off. the drive gear JUST tickles the ring gear. i'm about to get out the die grinder and shave off an 1/8 inch and make the work
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
