2001 LB7.. This thing has issues.
Old Nov 13, 2009 | 10:12 AM
SStibi's Avatar
Default 2001 LB7.. This thing has issues.
I have been working with my sisters 2001 2500HD for a while now keeping it going.
If it is parked at an angle where the front is higher than the rear the truck will NOT start, No if and or but about it. Have to prime the system to get it to fire.
The sucker gets 25mpg average driving and about 20 if you are laying some rubber down at every other stop light.
When it is idling the rpm surges up about 50RPM and drops back down instantly and it does this about twice a minute.
I was wondering if some of this was normal.
The truck is bone dry, it is not leaking a single drop of anything (well, except the axle seal is going).
So far I have changed all the u-joints, wired in some new speakers, changed the oil about a dozen times, and done the water pump (something I swear I'll never do again).
Old Nov 13, 2009 | 10:14 AM
Whit's Avatar
Site Mascot
fuel filter?
Old Nov 13, 2009 | 10:27 AM
2500HeavyDuty's Avatar
check the fuel filter first, replace it even if it has 5k miles on it. and check for leaks in the fuel system.
Old Jan 11, 2010 | 10:43 AM
TORXBIT's Avatar
the no start on a hill is most likely the fuel filter housing. its an internal issue with that adapter that loses prime.
the idle surge is most likely going to be the fuel pressure regulator (FPR). if you want to see it graphed take it to a dealer and have them plot the rpm, actual & desired fuel pressure, when it surges you'll see a jagged line...
Old Jan 14, 2010 | 06:34 PM
Vrabel's Avatar
Old Jan 15, 2010 | 10:17 AM
Dirtymax4955's Avatar
i would put in a new fuel filter and see if that will fix it.
J. Nick
Apr 25, 2015 05:01 PM
dshopex4
14
Apr 15, 2015 09:40 PM
Oleoleson
Mar 28, 2015 06:20 PM
octopusmotor
Mar 19, 2015 02:22 PM
metrickjb
Jan 21, 2015 04:16 AM
