7.3 idi dies under a load.
Old Nov 12, 2009 | 10:27 PM
bigpig's Avatar
Default 7.3 idi dies under a load.
I have a 1990 7.3 f-350. It will start and run as long as I don't get on it real hard. If you put your foot in it it will fall on it's face and die. After a few minutes it will start back up.
I have changed the injector pump, and the return lines. It's running better than it was, but still dies. I'm ready to burn it.
It's a 1990 f-350 7.3 with an automatic trans.
I'm thinking fuel pump next....
Old Nov 13, 2009 | 02:45 AM
biged681985's Avatar
sounds like it could be sucking air from somwhere. is it hard to start somethimes? id check supply lines first
Old Nov 13, 2009 | 09:29 PM
bigpig's Avatar
I have checked them, I'll look a little closer from the tank to the pump. Thanks
Old Nov 18, 2009 | 10:34 AM
sootman73's Avatar
i would def check into the lift pump. probably dont have the pressure needed at the IP.
Old Nov 20, 2009 | 09:10 PM
bigpig's Avatar
Thank you Sootman73, I did get a new pump. As soon as I get time I'll put it on. Right now I'm on my way to Amarillo...
Browe347
Dec 11, 2016 02:59 PM
GarrettEvan
Jan 30, 2016 05:39 PM
Toms73
Mar 23, 2015 08:31 PM
Texasthb
Mar 4, 2015 08:20 AM
Browe347
Sep 30, 2014 11:35 PM
