Just bought a hx35! install Q.
Old Nov 12, 2009 | 12:15 PM
Dozey's Avatar
Default Just bought a hx35! install Q.
I bought a stock turbo from a 95. hx35 with a 12cm wastegated exh side. Paid 225 from classified section. Question is I know it will bolt up but I am on serious budget due to time of year. Is it the same length front to back meaning am I gonna have dp problems or will it fit that too?
Old Nov 12, 2009 | 12:32 PM
TTipsword's Avatar
i think it would fit. does it have the cast elbow? if it does then you might have to clearence the firewall with that 5 pound piece of steel thingy on a stick.
Old Nov 12, 2009 | 01:49 PM
Dozey's Avatar
not sure have not received it yet. does anyone know what the eom style is for a 95. FYI reading a lot on these forums as i was looking stay away from EMUSE, those are the crap china ones.
Old Nov 12, 2009 | 06:09 PM
440ctd's Avatar
I would imagine it would fit. easiest way is with that cast elbow but I completed my diesel with a super hx40 and that was complete custom made bends and downpipe
Old Nov 12, 2009 | 06:30 PM
cumminskid92's Avatar
holset is the OEM. cummins actually owns the company
Old Nov 12, 2009 | 09:16 PM
1990cummins's Avatar
i had one on my truck for a short time the stock down pipe will work it is a bit of a pain to get on do to the fact that the exhaust housing of the hx35 is longer but so long as you leave the bottom mount on the down pipe disconnected you should be alset
Old Nov 13, 2009 | 12:56 PM
Dozey's Avatar
If I'm poor and still saving for my gauges and have very mild pump tuning could i still be safe to put this turbo on with its 12cm wastegated exh. and not cause heat damage? its a 5spd trk.
Old Nov 13, 2009 | 04:36 PM
921stgen's Avatar
Alot of members on DTR swear by the 12cm housing on 5peeds. It will be fine. You could always leave your stock exhaust housing on the truck and swap the rest.
Old Nov 13, 2009 | 06:29 PM
12vcummins96's Avatar
hey bud you will be fine it will bolt up but will have to move the downpipe abit as far as egts you will be fine to did you post in the contest for the guages
cummaprt704
May 9, 2015 04:09 PM
tecklancer
Apr 9, 2015 08:16 AM
2ndcummins1
Mar 9, 2015 10:01 AM
Bernardo153
Feb 24, 2015 10:13 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
