overdrive solenoid
Old Nov 12, 2009 | 12:01 PM
rollincoal12valve's Avatar
Default overdrive solenoid
any body heard of it?
i think its why i have no overdrive. what can i do to fix it?
any help please
Old Nov 12, 2009 | 08:00 PM
tdiezel's Avatar
Its a little dome shaped thing if I remember right. Its real simple but make sure you get a 12v one and not a 24v one or it will cause problems. You can just order one and put the new one in to solve your problem. I can't remember for the life of me where its located though. Someone will chime in and help im sure.
Old Nov 13, 2009 | 07:46 AM
BAD ASS RAM's Avatar
to test it unplug the main plug on the side of the tranny and hook up a lock uop switch except splice into the orange and black wire i think it's pin #1.that takes the computer out and you are actually grounding it out without going through the computer.
Old Nov 13, 2009 | 07:53 AM
12vcummins96's Avatar
thats right for the lock up switch but thats not overdrive overdrive is a seperate part of the tranny thier is the lock up clutch in the torque converter and thier is overdrive thier is a difference make sure you are looking for the right thing is it lock up that is not working or is it the overdrive
Old Nov 13, 2009 | 12:46 PM
if it is shifting into 4th gear then the lock up solenoid is good.all he sai was wrong was that it won't lock up.
Old Nov 24, 2009 | 03:28 PM
well i cant figure out if it isnt locking up or if i have no overdrive i just know it will only do 70 mph with 3.55s
camp9
Mar 25, 2017 07:40 AM
FF131
9
Mar 26, 2015 07:06 AM
thetrot
Jan 15, 2015 09:51 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
nevadagramm
Oct 17, 2014 07:59 PM
