Ahhh winter.
Old Nov 12, 2009 | 10:58 AM
Budgreen's Avatar
Default Ahhh winter.
Since all of us up north have prepped and or are prepping for winter and cold operation I have a question to pose.
Do you run a grill cover when it's really cold? advantages/disadvantages
every now and then I will see a truck running with one, but no first gen cummins powered dodge's to be seen around me.
Old Nov 12, 2009 | 11:10 AM
Whit's Avatar
Site Mascot
I completly cover my grill and also take my fan off.................we only use 20% of our cooling system under normal use
I take the grill cover off if I do mountain passes, also if you are going to tow leave the fan on
I have a temp sensor in my intake horn so I can monitor everything well.........also watch coolent temps.......if you run fanless never run yer A/C
Old Nov 12, 2009 | 11:18 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
here in wv most guys dont cover. if it gets down to zero truck cant get the coolant up to temp but that weather dont last to long here.
Old Nov 12, 2009 | 06:14 PM
440ctd's Avatar
I guess on the upside you would get heat faster. personally I wouldnt do it unless it was like 0
Old Nov 12, 2009 | 06:15 PM
tower_ofpower's Avatar
what pap said... usually a week TOPS if we get that bad; other than that it just takes forever to heat up... runnin the cover just speeds up warm up; and if you run an intercooler it can help it from icing over and causing an overheat b/c of blocked flow too... that's like whits problems
Old Nov 12, 2009 | 06:20 PM
wildbill's Avatar
I cover the radiator here also. Temps in the teens and colder, and on goes the piece of cardboard.
Old Nov 13, 2009 | 12:19 PM
TTipsword's Avatar
i need to figure somethin out for my truck. our first good snow we had about a month ago i couldnt get my truck to get warmed up worth a $%^t. i need to cut out a big template from cardboard i suppose.
Old Nov 13, 2009 | 12:56 PM
Budgreen's Avatar
my truck is hit or miss.. I keep losing radiator fluid anyways.. seems i have a randomly leaky hose *shrug* maybe i can fix that this weekend id somewhere has hoses in stock. and I think i'll prep up a grill cover to use if I see the need, supposed to be a colder than normal winter.
Old Nov 13, 2009 | 01:21 PM
K50's Avatar
K50
I've been running a cover for several weeks now. Temperatures hovering around -10C at night to plus 8C during the day. It helps keep things toasty especially when my truck is empty. Loading up the bed can make even more of a difference than just a winter front.
I'm too lazy to convert to imperial...
Old Nov 13, 2009 | 01:26 PM
DB Admin's Avatar
Banned
I use these
https://www.dieselbombers.com/baseme...er-fronts.html
