Is it safe to bore a 7.3 1990 .030 over?
Old Nov 11, 2009 | 11:18 AM
Contndr's Avatar
Default Is it safe to bore a 7.3 1990 .030 over?
I have a 1990 7.3 IDI with a ATS turbo on it. At 227K mile I broke a piston and need to sleeve that cylinder. Is it safe to bore the other 7 cylinders .030 to clean up the block? I bought this truck new in 1990 and use it to pull an enclose 24 ft. car trailer. Any help would be greatly appreciated!
Thanks,
Contnder
Old Nov 11, 2009 | 05:38 PM
Sycostang67's Avatar
With the cavitation issue these blocks have, I wouldn't think so. Most guys sleeve the motor back to a 6.9.
Old Nov 12, 2009 | 09:04 AM
Contndr's Avatar
Thanks for your help! Not sure whether to sleeve my block or go with a reman. engine. I have heard horror stories with some of the remanufactured engines.
Thanks again!
Old Nov 18, 2009 | 10:40 AM
sootman73's Avatar
its safe to sleeve but only if the machine shop you go to knows what they are doing. there has to be a step machined at the bottom to hold the sleeve in place or the sleeve will fall down and i'm sure you can imagine what happens then
Old Nov 30, 2009 | 08:08 AM
Contndr's Avatar
Thanks Sootman! I teach automotive and machinists classes at a community college in Virginia, but this is the first diesel that we have had to machine. I see that they make .030 over pistons for the 7.3, but wasn't sure if it is safe to bore that much.
Thanks,
Contndr
VonSchmidty
Feb 28, 2015 09:32 PM
