e4od transmission problem
Old Nov 11, 2009 | 12:17 AM
cnr1982's Avatar
Default e4od transmission problem
I havea 1992 ford 7.3 diesel. I just nowhad to repace the radiator and switched it with a manual one. I put a transmission cooler on it to make up for the rad not having one. Anyway since I have driven it today It goes into gear and drives good until it goes ito either 2nd or 3rd. Then it does a hard shift and acts like it not going to go into gear at first. Then it does and it wont switch to over drive it stays in 3rd. I have never had a problem switching the cooler like that before. I was thinking a sensor may hve went out or even the overdrive button, cause it doesnt do anything pushing it either way. Any help would be appreciated.
Thanks
Old Nov 11, 2009 | 01:25 AM
12vcummins96's Avatar
is the od light on the switch flashing if so u have a internal tranny issue
Old Nov 11, 2009 | 06:07 PM
cnr1982's Avatar
it doesnt act like its internal, it acts like a slynoid went out. Does any think that could be it? I have had transmission act funny before they go out befor, but never like this. I had a chevy that had to be babied untill you got up to 60 mph and it was sylnoid.
Old Nov 11, 2009 | 06:24 PM
Jet A Fuel's Avatar
I would double check the fluid level.
Old Nov 11, 2009 | 06:28 PM
cnr1982's Avatar
I did the fuel level is ok
Old Nov 11, 2009 | 06:35 PM
Jet A Fuel's Avatar
was it a new trans cooler could it have had debris in it?
Old Nov 11, 2009 | 11:33 PM
cnr1982's Avatar
Yes it was brand new out of the box. and no debri was in it.
Old Nov 18, 2009 | 10:44 AM
sootman73's Avatar
these transmissions need two or three more quarts of fluid than what the dipstick says. there is actually an update they perform on the dipstick where they grind a new mark about a quarter in above the full line. they can run dry easily on grades(boat ramps)
is the OD light blinking on the shifter? could be a solenoid pack as they do lots of different things when they go out. do not buy a remanufactured one as they are likely not any better than what you had before.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
02Stain
Feb 17, 2015 10:21 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
