Inj. pump mods make no change
Old Nov 10, 2009 | 07:08 PM
diesel57's Avatar
Default Inj. pump mods make no change
Hi, I did all the modifications to my inj. pump, but it made no difference in smoke or power. It is very slow on take off, and not much power on hills. When I look down the bore where the diaphragm and pin go I see no pin in there to ride on the tapered shaft, could it be stuck in, and causing it not to get enough fuel, if so what is the fix? rebuild kit or rebuilt pump? if so, where can I get them? Thanks for your help.
Old Nov 10, 2009 | 07:19 PM
dieseldawg's Avatar
you wont see the pin unless you gently open the throttle but only a bit then it will pop out
then befor you put the fuel cone back in push the little pin back in! hope that made sence
have you changed the fuel filter???
are you sure you are getting full throttle? the throttle cables stretch quite a bit!!
being that you have a non ic motor you should feel a huge difference with just pump mods!!
just with pump mods i made 100hp and 200tq over stock!!!!
Old Nov 10, 2009 | 08:26 PM
seandonato73's Avatar
yeah, i noticed major improvements to my 90 when i started "playing" with my pump....
what all have you adjusted so far??
Old Nov 10, 2009 | 09:44 PM
RSWORDS's Avatar
If all you have messed with is teh fuel pin and smoke screw you wont see to much inpovement. What mods have you done?
Old Nov 10, 2009 | 11:49 PM
sweetv8s10's Avatar
I had the same problem with mine and I had to take the throttle lever off and behind it is a plug its an allen wrench plug I took it out and then you can push it back in .Make sure you put your tapered shaft in where you need it first then push it in that should fix it.
Old Nov 11, 2009 | 10:21 PM
umm explain what you just said, what are you pushing back in?????
Old Nov 12, 2009 | 12:00 AM
dieseldawg's Avatar
i agree i like adjustments!!
Old Nov 12, 2009 | 11:33 PM
sweetv8s10's Avatar
Inside the hole is where the pin is at.That is what your pushing back in.
On mine the pin would stick and it actually felt weaker.I only figured it out because i took ot back apart and the diaphram would come out with out turning the tapered shaft.
Last edited by sweetv8s10; Nov 12, 2009 at 11:33 PM. Reason: Automerged Doublepost
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Spiderman
Oct 13, 2014 04:47 AM
