redneck way to set timeing?
Old Nov 10, 2009 | 04:36 PM
bowtech's Avatar
Default redneck way to set timeing?
i heard there was a way to set your timeing with out tools to within a 1 or 2. Any one know how to do this?
Old Nov 10, 2009 | 04:46 PM
monster12valve's Avatar
only have seen it done with the tools
Last edited by monster12valve; Nov 10, 2009 at 04:46 PM. Reason: Automerged Doublepost
Old Nov 10, 2009 | 05:21 PM
06 DIESEL's Avatar
Yes there sorta is, but it is more complicated than using the tools. Depending on the pump you can set the lift by the clicks of a baring tool, I have used this to re-set a pump that kept jumping timing while we were trying to set it.
It is quite a bit easier to just buy yourself the timing kit and set it properly though.
Old Nov 10, 2009 | 08:17 PM
440ctd's Avatar
I agree with what was said above its much easier using the timing set than finding another route
Old Nov 11, 2009 | 01:01 AM
Accuracy is very important here - I know its not what you want to hear - but you NEED the proper tools to do this.
Old Nov 11, 2009 | 01:27 AM
12vcummins96's Avatar
u can get the proper tools on ebay or snap on sells one to
Old Nov 11, 2009 | 09:16 AM
PhilipR's Avatar
I would not do it this way but I have heard this has been done:
It was described to me that you set TDC and push in the pin, pop the gear on the P-Pump and then pull the pin and roll the motor with the alt and put the gear back on. They claim that 1/8" move of the belt in reverese rotation will advace the timing 2*.
Old Nov 11, 2009 | 11:21 AM
94 12valve's Avatar
there is always the spill port method
Old Nov 11, 2009 | 06:30 PM
Hammer's Avatar
That ia actually the most accurate way to set the timing,however most shops do not have the knowledge to do it this way.
Old Nov 12, 2009 | 11:00 AM
94 12valve's Avatar
there is also a timing gun that works off the pulse of the #1 injector line.I have never used one but I would like to.
