Killer Dowel Pin question with a pic
Old Nov 9, 2009 | 02:13 PM
tltruckparts's Avatar
Default Killer Dowel Pin question with a pic
so while i just pulled out my injection pump i wanted to kill the kdp problem as well. but ive looked at all the pics and mine looks completely different. anyone know why mine looks different than everyone elses? and is there a different way to fix this case. here is a pic. thanks
Old Nov 10, 2009 | 09:27 AM
cumminsfreak86's Avatar
Looking at the picture, I see no reason why you couldn't put a step in your tab (if you were planning on using a tab). what I mean by a step is if you looking at the tab from the side it will look like a step in a set of stairs.
I had to do that when I tabbed my pin. How were you planning on fixing it? Are you using a kit or just planning on buying seals and gaskets and peening the area around the pin?
Old Nov 10, 2009 | 10:43 AM
i almost just though about using this glue compound i found at the auto store that has the tensile strength of a weld its some nasty stuff. i dont need gaskets and a seal i already have them. if i dont do that (i dont know if itd be bad or not) than i will just build a tab.
Old Nov 10, 2009 | 11:30 AM
Ive never heard of the glue stuff being used but I cant see why it wouldn't. Make sure you put locktite around the bolts in the timing case too. They have a tendency to fall out and can cause just as much damage. I think there are 5 or 6 of them.
Old Nov 10, 2009 | 11:34 AM
Bob Beauchaine's Avatar
I've seen the damage that the timing case cover bolts can do. Camshaft broken into 3 pieces 6 bent push rods. The only good point was that the engine was still good.
Bob
Old Nov 10, 2009 | 10:26 PM
MUDDY's Avatar
harold makes tab kits for both the 2nd gens and stepped tabs for the first gens. as far as i know harold is the only one making 1st gen specific tabs. [member hbowers]
and ditto to bobs post. was nasty carnage from the bolt coming out. witnessed more than 1 with a bolt coming out and witnessed lots of dowel pins out in both 1st and 2nd gens.
Old Nov 11, 2009 | 06:09 PM
hbowers's Avatar
you need to tab the dowel w/a stepped tab,take out the bolts one at a time,clean bolt and hole w/brake cleaner and compressed air,and loc-tite bolts. they are 5 bolts inside
case. you can remove 4 of them (one at a time) THE5TH ONe about all you can do is make sure its tight w/ abent 10mm open end wrench.
If a bolt ever falls out it will do more damage than the dowel pin will. 1n 1st gens a bolt is as apt to fall outas the dowel pin.
Old Nov 11, 2009 | 09:13 PM
RSWORDS's Avatar
I have seen people bend a peice of thin steel rod (think coat hanger size) to tab the KDP. Moght be an easier solution.
Old Nov 11, 2009 | 10:16 PM
would the glue idea or jb weld work or is that not a good idea? my guess is it it keeps the tab from falling out it does the job am i right?
Old Nov 12, 2009 | 02:56 PM
dgfordman's Avatar
If it was my truck i would'nt glue it cause i would always be worrying if it was gonna hold. just build a step tab or make a small shim for a flat tab. good luck
Weeks327
May 11, 2015 10:43 AM
