Head light issues
Old Nov 8, 2009 | 02:22 PM
tworks's Avatar
Default Head light issues
Hello all. A friend of mine has an 06 3500. His rt head light went. We changed bulb and still no light hi or low. Check for power/ground , found no signal from front light modual/underhood fuse panel. Any thoughts. We ended up using the inputs to lt light and a relay to make rt light work. thanks
Old Nov 8, 2009 | 03:41 PM
RedRammer's Avatar
I wonder if it couldn't be in the signal light circuit. I assume the US versions turn the corrosponding headlight off during signaling as well.
Old Nov 8, 2009 | 04:12 PM
wildbill's Avatar
If the DTRL's are enabled, the lamp shuts off when you activate the turn signal. I would look at that first.
Old Nov 8, 2009 | 07:14 PM
tworks's Avatar
With the headlights manually turned on is when the hi and low don't work on rt side . I will look into the drl modual thanks
Old Nov 8, 2009 | 07:17 PM
wildbill's Avatar
DRL is enabled in the ECM on the 3rd gens.
mfrank1296
Sep 10, 2015 01:23 AM
Jul 24, 2015 09:30 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
Adam65
Jan 9, 2015 11:50 PM
yams
Dec 7, 2014 12:51 PM
