airjack
Old Nov 8, 2009 | 05:52 AM
airjack's Avatar
Default airjack
hi everyone im new here just bought 02 cummins drove 90 miles home and found tranny fluid all around transfercase the tranny had been modified at some point shifts well fluid level ck ok and clean its all over bottom of truck cant see wher its coming from seal areas look ok also engine oil ck ok in safe area when ileft used truck dealer at home its just below safe line and engine oil all over front bottom of engine im a little mad i got another truck day before and tranny blew up on way home this dealer in va. is supposed to be reputable can any one help also truck has 160000mi. k&N intake and 4inch exuast
Old Nov 8, 2009 | 06:12 AM
Jazz's Avatar
Welcome to DieselBombers The oil you see all over the bottom could just be from the oil blow by tube or maybe you have a leak around your turbo oil lines or turbo seals. Do a search of oil blow by tube and you should find plenty of info
Old Nov 8, 2009 | 07:28 AM
mishkaya's Avatar
Oil leaks are not uncommon unfortunately on these vehicles. It seems as soon as I fix one, I find another... I would suggest trying to clean it all up to see if you can find where it's coming from and take it from there.
Old Nov 8, 2009 | 07:49 AM
Shea@L&N Performance's Avatar
FormerVendor
Welcome to the forum. As these guys said, clean it all off and see if you can pinpoint exactly where its coming from.
Old Nov 8, 2009 | 04:03 PM
01trailerpuller's Avatar
Checkout 24 Valve 2nd Gen Dodge Cummins 98.5-02 - Diesel Bombers
Old Nov 8, 2009 | 04:05 PM
wildbill's Avatar
Old Nov 8, 2009 | 11:21 PM
97cummins's Avatar
Old Nov 9, 2009 | 07:30 AM
CumminsMech's Avatar
Old Nov 9, 2009 | 08:35 PM
Nitelord's Avatar
Old Nov 10, 2009 | 01:02 PM
Uncle Bubba's Avatar
Be sure to post this in the truck tech section so we can get ya fixed up here. I bet new seal will fix ya up on most of this. The driveline seal on the tranny and if i had to make a bet the vacuum pump seal on the motor oil.
