compound turbo setup
Old Nov 7, 2009 | 10:18 PM
CumminsPowerOrNoPower's Avatar
Default compound turbo setup
Can you compound a HX 35 and a HT3B turbo, or would that be a bad idea?
Old Nov 7, 2009 | 10:21 PM
There are alot of people out there running that setup.
Old Nov 7, 2009 | 10:22 PM
Very nice. Do you know what kind of pressures those people are pushing?
Old Nov 8, 2009 | 09:32 PM
sstockton's Avatar
Depends on fueling. Its possible to push 55-60lbs with it. You will want to address the exhaust side of the hx35, as they are quite restrictive. Either an external wastegate, or a larger housing with a ported wastegate.
Sean
Old Nov 10, 2009 | 06:33 AM
I see, but i got someone that is offering me a killer deal on an HT3B and I think i'm going to try and buy it.
Old Nov 10, 2009 | 10:25 AM
nbaca's Avatar
try and find a used 14cm exhaust housing for your hx35.
Old Nov 10, 2009 | 10:29 AM
Wyatt Earp's Avatar
It is a very dependable setup and frankly is the one I would build. I know a few 12V trucks set up this way running 58# boost just fine. Granted if you push it or anything that hard you will need studs and such but it can be done. The numbers are very similar for a 24V (ISB) truck.
avatardvr
18
Aug 8, 2019 12:38 AM
Rockin-coal-01
Apr 7, 2015 07:58 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
