Injector #3 NOT COMING OUT!
Old Nov 7, 2009 | 10:00 PM
jameszadubara's Avatar
Default Injector #3 NOT COMING OUT!
I've been pulling and wiggling and twisting and it won't come out. Anyone encounter anything like this?
1991 D250 5.9 2 wheel 3 speed
Old Nov 7, 2009 | 10:06 PM
RSWORDS's Avatar
hhhmmmm..... Have you made a puller?
https://www.dieselbombers.com/1st-ge...r-install.html
Old Nov 7, 2009 | 10:13 PM
i havn't. don't have an arc welder.
Old Nov 7, 2009 | 10:21 PM
RSWORDS's Avatar
I've done it without a welder. Use two nuts, one as a jam nut on the other.
Old Nov 7, 2009 | 11:05 PM
big bad diesel 416's Avatar
Site Sponsor
ues a rag and some vice grips on the 2 flat sides use never seez on the install too
Old Nov 8, 2009 | 08:13 AM
stillcummin's Avatar
try turning the engine over(with the starter) with it loose in the head
Old Nov 8, 2009 | 10:30 AM
if you're not talking about turning the key in the ignition to start, i need more info.
Old Nov 8, 2009 | 11:59 AM
tower_ofpower's Avatar
take the hold down nut loose on the injector; put somethin heavy over the injector you're planning to pop loose; cut the fuel off and crank the engine... the compression will most deffinately blow it loose. gotta love this site; always read some interesting solutions from some of the best
Old Nov 8, 2009 | 01:30 PM
RSWORDS's Avatar
You MUST close the manual fuel cut off to do this, Or you will pump ALOT of fuel all over the place!
Read below!
Last edited by wildbill; Nov 8, 2009 at 01:40 PM. Reason: It's the not teh, flippin proof read.
Old Nov 8, 2009 | 01:55 PM
shortbusdriver's Avatar
injector removal - Dodge Cummins Diesel Forum
good luck
