Who's E-Brake actually works with bigger tires?
Old Nov 6, 2009 | 11:16 AM
Wyatt Earp's Avatar
Default Who's E-Brake actually works with bigger tires?
Hey,
I'm wondering who's parking brake actually works on this vintage of truck? I have always had issues with mine as soon as the bigger tires were put on it.
I've tightened the cable a couple times but this doesn't do much. Any other ideas?
Old Nov 6, 2009 | 11:24 AM
stkdram55's Avatar
mine hold decent with 285's on it...i use it on flat and slight inclines but when it gets steep i use it and throw it in gear too
Old Nov 6, 2009 | 11:34 AM
Wyatt Earp's Avatar
I have to throw mine in gear and usually 1st or rev or it rolls. The trouble is, it's getting colder and the time for increased indling is upon us - can't idle with a stick in gear.
Old Nov 6, 2009 | 11:49 AM
Mine works like the day it left the lot. About the only thing that does work good.
Get a Line Lock.
stkdram55's Avatar
get a few 4x4's to chock the tires if your that worried about it
Old Nov 6, 2009 | 11:54 AM
Wyatt Earp's Avatar
What's a line-lock?
My truck rolls as if there is no brake - almost level ground and it moves.
Nevermind - I figured out what it is.
Old Nov 6, 2009 | 11:55 AM
stkdram55's Avatar
maybe your back brakes are worn out, maybe your calipers are junk in the back
and a line lock is like what drag racers use when they do burnouts to lock the front tires so they dont fry there back brakes
Old Nov 6, 2009 | 11:57 AM
Wyatt Earp's Avatar
Pads and cali's are good. No codes but have had troubles with this for years. Just one of those things I've put up with and getting sick of it.
Old Nov 6, 2009 | 12:39 PM
guesswho512's Avatar
i had that trouble after i loaned my truck to a friend. he was used to automatics and forgot to unlock the ebrake. he drove about 6 miles before noticing(dumb *ss). since then i have to tighten my drums every month or so. i know that you calipers, but don't they use a dummy drum for ebrake?
Old Nov 6, 2009 | 12:46 PM
Wyatt Earp's Avatar
I don't remember to be honest but that would seem reasonable. I'll have to get that a check to be sure.
