6.0 Top Fuel Filter 1/2" O-Ring ???? HELP !!!!!
Old Nov 5, 2009 | 04:49 PM
LocoMike's Avatar
Bubble 6.0 Top Fuel Filter 1/2" O-Ring ???? HELP !!!!!
I need help dudes. I was changing the fuel filters in my 03 6.0 and found a broken O-ring in the 'fuel bowl' TOP 4 micron filter housing. The o-ring is about 1/2" (NOT the cover O-ring). If anybody can verify where it goes, if it's an OEM part or best yet, send me a parts diagram for this housing/regulator I would really be grateful.
My AutoEngenuity program says my pumps is running 99.9% and my fuel pressure at the housing tap is 50 PSIG. I "THINK" the O-ring is letting fuel bypass but need advie or a drawing to confirm.
Thanks in advance !!!!!
Old Nov 5, 2009 | 06:44 PM
Big Angry Hillbilly's Avatar
Picture of said O-ring please?
It may be the O-ring from the inside of the old filter.
Look inside the old filter, there should be a back o-ring right at the top.
Measure your fuel pressure at WOT in 3rd gear, unless you have the proper bypass tool for checking 6.0 fuel pressure.
Old Nov 5, 2009 | 08:55 PM
LocoMike's Avatar
YOU were dead on my friend. Except I found more.......
Apparently the last time the sdealer serviced it they crushed the filter in. It didn't line up in the notches and I found that the plunger (stem) was broken off and rattling around inside my old filter
THANKS for your time !!!
Old Nov 6, 2009 | 12:30 PM
I am so tired of hearing about dealership hacks...they make ALL the dealer techs look bad.
Sorry to hear about that.
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
