Injector Lines
I've got a 2000, two injector lines were rubbing together and nearly wore through; so now I need to replace #2 and #6 lines, my dodge dealership wants $389 for the two lines...is there a reasonable alternative to this?
I know there are pretty big oversize injector lines available from Scheid's and their vendors, Pure Diesel Performance has .078, .084, .093, .093 & .120 listed from $399 and up...with a warning not to use larger than .084 with a stock VP as it may cause stalling at idle.
So I should be okay with .078 lines, right? Anyone know for sure? This 2000 is a manual, so it's an HO with the bigger HX35 and slightly larger injectors and we're getting a mild programmer for it, so as far as I can tell, the slightly larger .078 lines shouldn't cause me any grief...am I wrong?
If those lines rubbed odds ar pretty good that you have one a the blue tabs either missing or moved in the wrong place. May want to check it out before it happens again. Wait till ya price them little blue tabs sometime. My jaw dropped off the floor.
