LP questions
Old Nov 4, 2009 | 07:28 PM
NCFPD's Avatar
Default LP questions
Hey I am about to put the raptor 150 pump on my truck bec. my stocker lp is weak i am also instaling the quad add. my queastion is if at some time my stock lift pump goes out will the raptor be able to push enough fuel or any at all threw the stock lift pump how does that work i am curintly replacing the the IP bec. the LP is week so i am going to install the raptor 150 now
Old Nov 4, 2009 | 07:37 PM
Whit's Avatar
Site Mascot
remove the OEM pump and toss it as far fart as you can......the Raptor is designed to be a stand alone pump.........dont run them in series
Old Nov 4, 2009 | 07:49 PM
NCFPD's Avatar
ok thats cool
nbaca's Avatar
my raptor 150 pushes plenty of fuel all by its little self. take the stock pump and use it as a paper weight thats all it is good for. run all new lines with the raptor. from tank to raptor to the fuel canister and your good to go. you want to stay between 10-20psi.
Old Nov 4, 2009 | 08:03 PM
NCFPD's Avatar
Hey will it come with the lines and hard ware to do that
Old Nov 4, 2009 | 08:29 PM
Whit's Avatar
Site Mascot
I believe so..............do you order just a pump or a kit or what???
Old Nov 4, 2009 | 08:34 PM
NCFPD's Avatar
i aint sure i will have to look i think the kit but i dont think it said what was in the kit
this is what it says
Complete Installation Kit With: No Drill Mounting Bracket, Wiring Harness, AND 1/2” Big Line Fuel Lines are Standard.
Unless you special order the Raptor from Pure Flow it comes with the whole kit.
Like Wit said.......... toss that OEM Pump as FAR as you can.
Luke
Old Nov 4, 2009 | 08:48 PM
NCFPD's Avatar
ok thats good you wouldnt happen to know the details of what comes in the kit like what adapters and how much line is it made to run from the tank to the fuel filter
Old Nov 6, 2009 | 08:43 AM
Mopar1973Man's Avatar
The only thing that the Raptor is missing is a short piece of 1/2" hose for the filter to the VP44 to pull the last bit of stock tubing out...
Draw Straw II 1/2 in. draw tube and 1/2 in. pushlock fitting
