Valve cover gaskets
Old Nov 4, 2009 | 05:56 PM
Pyro690's Avatar
Default Valve cover gaskets
I had 1 valve cover leak a little. I decided that since I just bought the truck, I should check the valve lash. Now 5 of them leak. They are all hard as a rock and I'm gunna replace them all. They all had RTV on them to Band-Aid it I guess. Is Fel-pro a good replacement? Thanks for your input.
Old Nov 4, 2009 | 06:26 PM
shortbusdriver's Avatar
got mine from Napa, not sure what brand they are though
Old Nov 4, 2009 | 06:38 PM
440ctd's Avatar
the rubber compound ones are the way to go it seems that the cork ones tend to leak over time
Old Nov 5, 2009 | 07:41 AM
PhilipR's Avatar
Napa's are probably Fel-pro..if they are old stock then they are Victor Reinz....both will be fine.
Old Nov 5, 2009 | 08:35 AM
12vcummins96's Avatar
felpro is perfety fine
Old Nov 5, 2009 | 05:22 PM
Pyro690's Avatar
Thanks guys.
Old Nov 6, 2009 | 11:45 AM
12.valve.hauler's Avatar
i always had good results with petty much everything felpro
Old Nov 6, 2009 | 02:48 PM
cummins_guy's Avatar
check to see if the little o-rings on the bolts are not bad, if those are not on or they are bad, that will cause oil to leak from the gasket.
I use Cummins gasket, they are grey in color, i have had all four colors on my truck before (red, green, black and grey) grey is the best, for me not sure why but they just worked and fit better.
I can get the upper gasket kit for 59.00 (this is Cummins OEM)
Old Nov 6, 2009 | 05:55 PM
chevycummins1@yahoo.com's Avatar
the cummins grey gaskets are the best, just make sure you don't overtorque the valve cover bolts. 18ft pounds max
Old Nov 7, 2009 | 08:49 PM
navalseabee's Avatar
agreed, i got rid of my black one and bought the cummins grey ones. theyre not rubber theyre like silicon sumin i think.
