Water/methanal
Old Nov 4, 2009 | 03:17 PM
12valvecory's Avatar
Default Water/methanal
Ok so I have heard alot of stuff about this like that u can use windsheild wiper fluid in it and that u could use ur wiper system for water meth. Just some questions
Old Nov 10, 2009 | 11:18 AM
bradenanders's Avatar
you can use your washer fluid tank but it would be better in getting a 3-5 gallon tank and mounting in the bed or underneath. It just depends on how much you plan on spraying. It would be a hassel to fill your washer fluid up every 100 miles or so. Just my thoughts
Old Nov 10, 2009 | 03:24 PM
dan33klein's Avatar
yeah i have a 25 gallon tank in my toolbox
lasts a while, unless im spooling my twins 24/7 when im towing
Old Nov 10, 2009 | 05:06 PM
mylilpwny's Avatar
does meth injection help out alot ?? i have herd yes and no .. and coming from a gas burner background not sure about diesels
Old Nov 11, 2009 | 01:00 AM
dan33klein's Avatar
yeah. i run mostly pure water in mine, im just looking to get the egt "cooling effect"
not so much the "power" effect. im running alot of power. i can be cruising at 70mph running 700* and flip my override switch and shell cool down to about 500/475* on a dime. i call that worth it. and it helps alot when towing a heavy load. cause you can stay in the throttle, keep your turbos spooling, and still maintain some pretty good egts.
i think its well worth the money. check out AIS(alcoholinjectionsystems.com) call up and ask for Rodney he will get you hooked up according to all your mods and hp ratings and boost ratings. hell tell you exactly what sizes and that you need for YOUR motor. not a motor in general. hope this helps good luck
Alot of water, not power sorry*
Last edited by dan33klein; Nov 11, 2009 at 01:00 AM. Reason: Automerged Doublepost
Old Nov 11, 2009 | 01:20 AM
12vcummins96's Avatar
i run water meth in my truck and love it the cooling effect is great and the power upgrade is noticable so i would say definetly
Old Nov 11, 2009 | 02:11 AM
mylilpwny's Avatar
ok so it works good on diesel also ... i have run meth kits on some of my other cars ... but they were mainly track cars and that was for after the runs to cool them off ... so wasnt sure wat its like for a daily status
Old Nov 12, 2009 | 07:01 PM
dan33klein's Avatar
yep their worth it
Old Nov 16, 2009 | 11:07 AM
YOUNG GUNS's Avatar
i run mine out of my washer tank. i dont fill up every 100 miles but about after 2 and a half tanks of fuel i have to fill it.
it just depends on how you setup your meth to come on. mine was at 25 but i lowered it to 15 and now i go through alot more.....
Old Nov 16, 2009 | 11:30 AM
NadirPoint's Avatar
like dan33klein said, the nozzle size needs properly matched to your fueling level for the desired effect. Running too big of a nozzle or too many nozzles(s) is a common mistake. More water does not necessarily mean more power/cooling. Regardless, you need a big tank, at least 5 gal if you tow, even with a low end stock-rated system. Otherwise it probably doesn't matter too much if you're not towing with it and spraying with the turbo spooled for long periods.
