injector install
Old Nov 4, 2009 | 02:50 PM
TTipsword's Avatar
Default injector install
anyone got a good link to a write up or instructions on how to pull injectors and put new ones in? Any help would be appreciated. Wanna make sure im not gunna miss anything.
Old Nov 4, 2009 | 04:01 PM
RSWORDS's Avatar
Not hard at all, they some times pop right out,
Remove the injector lines, then the hold down nut and pop em off. If they wont come out zip tie the fuel shut off on your pump to the OFF position, place a heavy towel over the injector to keep it from flying away and turn the engine over.
Or you can use vice grips, just watch teh thread.
Or you can make a simple tool to pull them.
Found these pics a while back some where
3 1/2" 3/4 black pipe, a 3" bolt, and nut, some washers, and a nut that fits the injectors.
Old Nov 4, 2009 | 05:11 PM
TTipsword's Avatar
[QUOTE=RSWORDS;424914]Not hard at all, they some times pop right out,
QUOTE]
don't threatin me with a good time like that!
Old Nov 4, 2009 | 07:42 PM
RSWORDS's Avatar
I've done it that way, easy. Just make sure you put the towel over them. Do one at a time.
Also start soaking them with penetrating oil.
Old Nov 4, 2009 | 09:15 PM
TTipsword's Avatar
will do. how about the copper seals?
Old Nov 5, 2009 | 04:52 PM
RSWORDS's Avatar
Just make sure they come out. 9 times out of 10 they are stuck to the injector. If not use a pick to get them. All they are is copper washers.
Old Nov 5, 2009 | 07:39 PM
TTipsword's Avatar
alright. thanks for the help. i think i will be ok to put them in as soon the post office finds them
