Group Buy Group Buys And Discussions of Group Buys On All Diesel Related Products
Scan gauge II group buy $149.95 shipped
Old Nov 4, 2009 | 11:09 AM
jkidd's Avatar
Default Scan gauge II group buy $149.95 shipped
Group buy for ScangaugeII $149.95 shipped
https://www.dieselbombers.com/diesel...5-shipped.html
I need 5+ people for this price. As soon as we get 5 people I can ship. I am running this on two other forums and hope to help equip people with a OBDII scanner/gauge set.
Here is their website
If you want one PM me your email address and I will send you an invoice through paypal.
Once I get 5 ordered I will send them, If I don't get 5 orders by Nov 10th I will buy the rest and stock them for future use. If 5 sell before then I will send them out sooner.
ScanGaugeII - Scan Tool + Digital Gauges + Trip Computers
I took a summary from their site:
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used
* Trip Fuel Economy
* Distance to Empty
* Time to Empty
* Fuel to Empty
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
* Fuel Economy
* Fuel Rate
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off the "Check Engine" light
* Tells you when vehicle is "Ready" to pass OBDII testing
* Make and store up to 10 rewritable special codes
to send to the vehicle computer
It will also do instant HP and you can change the color of the display
more functions herehttp://www.scangauge.com/support/pdfs/XGAUGE.pdf
These work on any OBDII vehicles usually anything 1996 and up. It will work on both of your vehicles, but you will have to calibrate the settings for each vehicle (for mpg/cost per mile etc, but it will still read temps and stuff). It will code read on any OBDII without need for calibration.
For Diesel applications I like using TPS for keeping constant fueling to get best MPG
For Gasoline applications I like using TPS and Timing to get best MPG, If your engine is pulling timing then you are not getting the full efficiency of the engine.
One of my favorite and my wifes LEAST favorite features is the trip history. You can see top MPH mpg per day and peak RPM. Never knew she drove a vehicle harder then me when I'm not in the car. now she can't deny it. Might be good for a teenager or an employee.
