fuel filter right?
Old Nov 4, 2009 | 10:54 AM
bowtech's Avatar
Default fuel filter right?
the filter on the driver side kinda under the brake resivor is the fuel filter right? How often you supose to change it?
Old Nov 4, 2009 | 11:02 AM
rkadcock's Avatar
N.M. Bombers Director
Yes thats the correct location. I believe its every 6k or 10k miles
Old Nov 4, 2009 | 11:04 AM
biged681985's Avatar
that would be it, on my stock one, i would change it every two oil changes, so around 10k. some say thats to often, but thats how i done my, some change theres every oil change. it depends .on the person, and quality of fuel u use. good luck
Old Nov 4, 2009 | 08:55 PM
Biggy B's Avatar
i wonder if using an additive will shorten the life of a filter ? cause half a quart of oil n half a quart of power services every 3 tanks its preety thick
Old Nov 4, 2009 | 09:12 PM
bowtech's Avatar
ok thanks are theresome filters better than others? where to get them? when you change it you have to prime it or any thing special
Old Nov 5, 2009 | 07:51 AM
PhilipR's Avatar
I would user the primer bulb on the pump and pushed it until the OFV was squealing than started the truck up.
Old Nov 5, 2009 | 02:13 PM
bowtech's Avatar
where the primer bulb at?
Old Nov 5, 2009 | 02:14 PM
PhilipR's Avatar
Right on the lift pump....
Old Nov 8, 2009 | 01:33 PM
lodal cummins's Avatar
or you can fill the filter full of diesel before you put it back on. that has always worked for me.
Old Nov 8, 2009 | 07:03 PM
Yellow Yota's Avatar
The right way to knowwhen to change your filter is to monitor your fuel pressure. A filter might last 30,000 miles,or it might be bad in 300 miles from a bad tank of fuel.
