Compression Test on 95 Dodge
Old Nov 4, 2009 | 06:57 AM
kyle_truck_pull's Avatar
Default Compression Test on 95 Dodge
Hi I just did a compression test on a 95 diesel truck, the truck has different pistons than stock but i dont know what kind, they are suposed to be lower compression. i had an average number of 460psi on each cylinder but #3 was only 400. I squirted oil in each cylinder and every cylinder jumped up to around 520. what are the stock pistons supposed to make? how do I know if mine is ok? and is #3 Bad enough to worry about. thanks!
Old Nov 4, 2009 | 07:42 AM
wildbill's Avatar
When it drops below 100 lbs difference, then you should worry. Stock pistons, with a turbo, make around 320-360. The lower compression coupled with the turbo prevents blowing out the head gasket. So I'd say your good to go.
Old Nov 4, 2009 | 08:13 AM
12vcummins96's Avatar
yes you are fine rock and roll buddy
Old Nov 5, 2009 | 06:42 AM
Thanks guys!
If stock pistons only make around 320-360, and mine is supposed to have lower compression pistons, I wonder why I am seeing 460? thanks
Last edited by kyle_truck_pull; Nov 5, 2009 at 06:42 AM. Reason: Automerged Doublepost
russellflemister
Sep 14, 2015 09:33 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
