EGT'S
Old Nov 3, 2009 | 08:32 PM
lodal cummins's Avatar
Default EGT'S
did my kdp and bumped timing to 15.5, love the response and lower egt's in town. however going over mountain passes with no load on i see 850 on the steep hills with o/d off going about 55 or 60. if i run in o/d going 60 to 70 it will be around 950 to 1100. that's not even mashing it!!! seems a little hot to me. running on the flats at 65 or 70 seems to be around 700 to 800. would hate to see the temps pulling a load over the pass. all chime in what temp you all are running. i guess it is time for 4" exhaust instead of the 3" with the areo turbine on it. i was told that it works almost like 4" because of the vacum it creates unless your pulling really heavy loads. hate to spend the 500 bucks on exhaust as i love the sound as it is now. but i'd rather spend the money on that than melted pistons.
Old Nov 3, 2009 | 09:05 PM
stkdram55's Avatar
I wonder if the altitude has anything to do with it... the air is less dense so its not getting as much
Old Nov 3, 2009 | 09:10 PM
well it is around 3500 to 4500 pass level. that is a good thought!!!! i go over it all the time so with these new mods and the mods to come i wonder if a intake elbow with the water port in that back is a good route to go?
Old Nov 3, 2009 | 10:36 PM
biged681985's Avatar
u can get a 4 inch for around 300 from any of the vendors on here. is ur egt probe pre turbo or post turbo? good luck
Old Nov 3, 2009 | 10:50 PM
it is pre turbo and how much lower will the 4" bring the temps down? i should run some steep grades around town (500 ft level) and see if they are alot lower.
Old Nov 4, 2009 | 02:07 AM
12valvetater's Avatar
you can make an exhaust for muh less than 300 bucks i have done it plpenty of times but with stock fuel youll have a little more back pressure as there is not quite enough to fill a larger exhaust
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
TheDirtyDozen
Nov 16, 2014 02:56 PM
