Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
Whats It Gonna Take To Pull My Truck Out?
Old Nov 3, 2009 | 04:43 PM
RSWORDS's Avatar
Default Whats It Gonna Take To Pull My Truck Out?
No I didn't get stuck!!!
This is a chart I have had for a long time, It is a VERY good reference fro how much pulling power you need to pull out a stuck truck. It will also show you how easy it is to blow right by the rated working limits of alot of your recovery gear.
Old Nov 3, 2009 | 07:26 PM
tdiezel's Avatar
Thats awesome information!! Thanks!
Old Nov 3, 2009 | 07:28 PM
Whit's Avatar
Site Mascot
reminds me of work........go to do a task and ya end up with a flow chart..................its good though Bobby
Old Nov 4, 2009 | 11:10 PM
Woody35's Avatar
what ever happen to hooking up the chains and giving it hell
Old Nov 4, 2009 | 11:27 PM
stkdram55's Avatar
i just usually think 2nd or 3rd gear??
Old Nov 5, 2009 | 11:38 AM
12.valve.hauler's Avatar
thats how i do it woody
try the fun way first and if that dont work then go to the techncil stuff
Last edited by 12.valve.hauler; Nov 5, 2009 at 11:38 AM. Reason: Automerged Doublepost
Old Nov 10, 2009 | 04:40 PM
RSWORDS's Avatar
After you buy a few tailgates and windshield you will switch to using a heavy *** strap and giving it hell!
I usually do that 1st.
This is more to help in choising a winch for your truck.
Old Nov 12, 2009 | 11:35 AM
screaminseema's Avatar
Chains work great if there is consistant static force... but that really never happens.
Old Nov 12, 2009 | 11:36 AM
RSWORDS's Avatar
Exactly
Old Nov 12, 2009 | 12:50 PM
dieseldude03's Avatar
I was always told a good rule of thumb for choosing a winch is it should be rated for at least 1.5 times the weight of the truck it's attached to, I.E. an 8000 lb diesel truck should have a minimum 12,000 LB winch.
If a straight line pull won't do it, simply use a ****** block at the anchor point and bring the winch hook back to the winch vehicle. The pulling speed will be cut in half but the pulling power will be doubled!
As Bobby said, you can see pretty quickly how easy it is to overload your recovery gear. With the use of a ****** block, several tree savers, or whatever you use for your anchor point, may need to be used.
Pulling promotions
Diesel Related Events
Sep 18, 2015 01:39 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
